Kinetic Light in Madrix 3
I recently purchased the Madrix PLEXUS to control a group of 60 generic Kinetic lights we purchased.
Tried following the tutorials on how to configure kinetic lights with Madrix 3 but I'm stuck since the DMX chart on my lights isnt the same as the one on the example.
the DMX chart of the lights is as follows
any help will be really appreciated
Thank you all in advance
Re: Kinetic Light in Madrix 3
Hello gonzaloecu84,
The fixture you want to use has another DMX address assignment.
Attached you will find 2 fixture profiles which you have to open in your MADRIX fixture library.
How to open a fixture in an existing library you can learn under the following link:
http://help.madrix.com/m5/html/fixturee ... tures.html
Please start the Fixture Editor in "Administrator Mode".
After you have load the fixtures to your desired fixture library please save the fixture library and restart MADRIX.
Now you should be able to patch this fixtures. When you patch the fixtures you can work according to the tutorial but please keep in mind you have to set the same DMX start address for the RGB ball and also for the winch. The correct channel assignement for the channel of the movment or the RGB ball is inside of fixture definition.
- Kinetic.zip
- (1.5 KiB) Downloaded 3958 times
