Madrix 5 with 2 separate Projects
Quinter
Post by Quinter »
Hello Evrybody
Im using Madrix 5 since some months and with some different Projects. Normally i only use 1 Project at the same time. (exemple LED WALL).
Now, i want to control 2 Projects (A Wall and A Star consisting of Adressable LEDs).
The Problem is, i don t know how i can run 2 Projects at the same Time with different Effects. 1 Project on the Left and 1 on The right Deck maybe. Hope someone can help me.
Greets
Marc
Re: Madrix 5 with 2 separate Projects
Hello Quinter,
When you want to output different content to different parts of the MADRIX patch /different areas I recommend to work with several layers per Storage Place and Map the effects to the desired positions.
Under the following link you will find some tutorials how to work with different layers in MADRIX:
http://help.madrix.com/tutorials/html/i ... ayers.html
http://help.madrix.com/tutorials/html/i ... mappi.html
Of course it would also be possible to use Storage Places on Deck A to playback effects which are mapped to the "LED Wall" and on Deck B Storage Places to playback effects whoch are mapped to the "Star". In this example you should have White Fade (WF) as fade time set an the Crossfader should be in the middle.
