screen capture
nmohanlighting
screen capture
Post by nmohanlighting »
hello
Is screen capture is temporary storage ? while doing screen capture it stored, but when shut down and restart the laptop the screen captured image will not be available in the stored button, please help me to store permanent image.
Re: screen capture
Hello nmohanlighting,
The SCE Screen Capture effect in MADRIX captures always the live content which is behind the set area. That means the SCE Screen Capture Effect don't creates a screenshot. If the desired image is not locaded at the set area after the restart of MADRIX and loading the saved setup, it will display any other content which is located there at the moment.
If the set area of the SCE Screen Capture effect is out of range after the restart, MADRIX will also display black. A reason for an out of range position is for example when the area is set to a second monitor and this second monitor is disabled at the next start of MADRIX.
When you want to reload the SCE Screen Capture effect with same capture area after the next start of MADRIX, you have to save the setup before you close MADRIX and load this setup again after the restart. If you don't load the setup and choose only the SCE Screen Capture effect, the capture area will be set to the default area.
Under the following link you can learn more about the SCE Screen Capture effect:
http://help.madrix.com/m5/html/madrix/i ... pture.html
If you want to display a stored image in MADRIX, you should use the SCE Image effect. Under the follwing link you will find more about the SCE Image effect:
http://help.madrix.com/m5/html/madrix/i ... itmap.html
