MTC
bew
MTC
Post by bew »
Hi all
i want to know how madrix receive another mtc such as reaper. I was tried with Timelord and that is success.
someday i event with reaper which sent the mtc. on madrix device manager the audio input i was changed with ASIO and on the madrix timecode i set to midi and the fps is 30fps.
unfortunatelly that doesn't work. madrix can't receive the mtc from reaper.
i dont know what is wrong.
i was checked all the time to setup the reaper but still madrix never receive the mtc.
does somebody know what i must set again?? and have the solution too.
thanks
Re: MTC
Hi there!
It can be done.
First, you will need a 'virtual MIDI cable' on your system.
In Reaper, you can use this virtual device as MIDI output device and send MTC to it. Please see chapters 23.6 / 23.7 of the Reaper manual on how to do that.
Make also sure to route the Timecode Generator to that output device in Reaper.
