Problem with CSV cue list import
moles93
Post by moles93 »
Hello everybody
Please help me,
I’m trying to import a csv file in a cue list whit 200 cues…
All works good, the problem is the timecode
If I insert in the csv timecode 00:00:36:05 Madrix not allow it, Madrix allowed if I wrote 36200
What is the conversion that I need to adopt?
So, in timecode I need to convert my timecode hh:mm:ss:ff to the allowed Madrix format?
The rest of the tab is perfect, I can load all the information, but i can't load the correct timecode…
Which language I need to convert it?
Please, a cooffe for who solve my problem!
Re: Problem with CSV cue list import
Hi moles93,
The timecode has to be assigned in milliseconds in the CSV-file (CSV-Cuelists are millisecond-based).
For example (framerate is 25 frames per second), which means one frame is 40 ms long:
Therefore you need to convert the frames (5 frames) into milliseconds, by multiplying them with the factor of 40 ms per frame, which results in 200 ms.
Have a nice day!
