Madrix Key
Madrix Key
Hie,
Ive purchased Madrix Pro. Im wondering can i install it on my laptop and make some patches before i install in the actual desktop at the outlet.
so can i install the software on 2 or more pcs ?
Re: Madrix Key
Hi mission_rave,
yes for sure this is possible.
This is one of the advantages using a hardware protection dongle (our MADRIX Key) based on USB. You can install MADRIX as many times you want and use the MADRIX Key to decide which one you use for generating output.
The software is for free and you can downloaded here from our website, what you have buy is the MADRIX Key.
The disadvantage of course is the MADRIX Key could be lost, therefor take care about him!!!
Re: Madrix Key
Can i take a backup ? what if the usb gets damaged?
Re: Madrix Key
MADRIX allows you to save all kind of settings. The most important file will be your MADRIX Setup. This file contains almost all information that is required for a show. This could be your backup. And you can create as many as you want.
The USB Key is quite robust, so it does not get damaged easily. However, it remains your responsibility to prevent any damage to this dongle or even loss.
Re: Madrix Key
i have a question i wanna ask ? my boss has bought your MADRIX SOFTWARE NEO ,but he didn`t get the MADRIX KEY usb dongle . The box with the dmx512 interface SN# NEO 000845 . Can you advise me what to do because the program need a key to work good !! thank you and im waiting on a email a soon as possible
Re: Madrix Key
The MADRIX NEO interface needs no USB MADRIX KEY, because the NEO is the KEY themself.
This means if you have installed the MADRIX NEO driver and pluged in the NEO to the PC where the MADRIX software runs the MADRIX software is able to send DMX data for one universe (it doesn´t matter if this one univers is send by this NEO or Art-Net or a different interface).
