wysiwyg visualization
alejandro094267
Post by alejandro094267 »
Hi i have a dude, need to link madrix 5 with wysiwyg.In madrix 3 i haven t problem with visualizator option but how can i do in madrix 5? i don t see any option.
Re: wysiwyg visualization
Hello alejandro094267,
You can easily send the data from MADRIX 5 to "wysiwyg" via Art-Net. There are no limitations by using Art-Net instead of a direct connection via the "wysiwyg port".
You only should start the "wysiwyg" software first if both applications should run on one and the same PC.
alejandro094267
HI , thank u for your answer, i used some days ago this way but... Don´t you think is more easy to include the visualicer option??? now i have to make manually all conection....
Thank you for the input.
At the moment you will have the possibility to connect MADRIX and "wysiwyg" via Art-Net or as second option sACN.
After you have add the desired "Connectivity" in "wysiwyg" of course you have to assign the output ports of the desired protocol to the desired Universes. After this step you can send the data from MADRIX and receive it in "wysiwyg".
