Remote Control of multiple Plexus
Clarence Thian
Post by Clarence Thian »
I have a potential project that will require the use of 2 universes on one building and another 2 universes on nearby building. There shall be times when the facade lighting of these 2 buildings shall be run independently, and yet needs to cater to special events where they shall need to work together via a tablet/smartphone linked to a network (and WiFi).
Can Remote be configured to activate scenes on BOTH Plexus units SIMULTANEOUSLY?
How is the mapping in Madrix to be done if this is do-able?
Re: Remote Control of multiple Plexus
Hello Clarence Thian,
It is not possible to solve the wanted behavior with two MADRIX PLEXUS. Bu if you want to use 3 MADRIX PLEXUS it is possible.
In that case one PLEXUS is respondsible to trigger the scenes for the synchronized output. This one will be the Master. It has no fixtures connected and only be used to trigger the Slave PLEXUS.
The other two PLEXUS will be connected to the DMX fixtures at the buldings and are working in Slave mode with the Master PLEXUS.
Now you are able to trigger the recorded scenes of the two Slave Plexus individually and it is possible by triggering the Master PLEXUS to playback a synchronized output at both buildings.
Clarence Thian
Can a single Aura and 2 Stellas do the same job?
Hi Clarence,
If you want to have the same content synchronized on both buildings you can use one AURA 8 and two MADRIX STELLA.
In case of asynchronous output (different content on both buildings), do you want to output the data live from MADRIX or should it also be a stand-alone with AURAs?
