Spout output result with blank spots
hendrawinata
Post by hendrawinata »
Hi Madrix,
First of all, thanks for the MAdrix 5.1 that allows spout in and out that creates many possibilities of interconnectivity.
Recently, I am trying to spout out to MadMapper to simulate the Madrix effect to a bridge image nd I find out that the lines created in Madrix perfectly but projected kind of with dash lines (blank discontinued lines in pattern).
Same thing when i tried to spout out to resolume same thing happened
I have tried to adjust the frame rate, increase the line thickness, etc. but result no difference
Hope to hear from you soon
Hendra W.
Re: Spout output result with blank spots
Hi hendrawinata,
Since I couldn't reproduce the issue, could you please send us your MADRIX setup via e-mail to info[at]madrix[dot]com?
Thank you very much.
