3203 compatability
Mikkelwest
3203 compatability
Post by Mikkelwest »
does anyone know if the nebula is compatible with the 3203 IC ?
thanks
Re: 3203 compatability
Hello Mikkelwest,
At the moment we didn't found any documentation/datasheet about the 3203 IC. If you are able to send us a datasheet of the requested IC, we can implement this IC to the NEBULA or check if it is possible to use an alternatice already existing protocol to control this IC with the NEBULA.
You can easily send us the datasheet via e-mail to info[at]madrix[dot]com.
