NDI WITH RESOLUME
victorfeller
NDI WITH RESOLUME
Post by victorfeller »
Hi Guys, i'm working on a event wich i have an led painel on the middle, and on the 2 sides i'll have 80 led tubes, 40 each side, wich 48 pixels , 2 pixels per 1 channel, so, i create an "NDI Output" on Resolume Arena, and create an SCE Capture wich found my Resolume Screen, but when i test the video on resolume to Madrix, he dosn't show anything... it's something wich i forgot to do ?
Re: NDI WITH RESOLUME
Hello victorfeller,
Can you please tell us if you are using both software (MADRIX and Resolume) on one and the same PC or on two PCs?
Please pay also attention to the following points:
  • Please double check that MADRIX and Resolume are running with the latest version.
  • NDI is a network stream. Please double check the firewall settings that the NDI stream will not be blocked.
  • If you are working with only with one PC, please double check if an active network socked is available.
  • Also if you are working with only one PC you can use SPOUT to communicate between MADRIX and Resolume.
