BV 318A LED controller
nmohanlighting
Post by nmohanlighting »
Dear sir
Can we use BV 318A LED Controller with Madrix sofftware
Re: BV 318A LED controller
Hi nmohanlighting,
MADRIX 5 allows you to output data via a wide range of industry standard output-protocols (for example: ArtNet, sACN, DMX512, Philips Hue, DVI, ...).
Here you can find more information about the output capabilities of MADRIX 5:
http://help.madrix.com/m5/html/madrix/hidd_output.html
https://www.madrix.com/products/software
That means if your interface supports one of the aforementioned protocols, you can use it with MADRIX 5.
I hope this helps you.
