MADRIX LUNA WIRING
jaime
MADRIX LUNA WIRING
Post by jaime »
HEY IM NEW WITH MADRIX I GOT LUNA 8 .I GOT MY LED PIXEL CONECTED BUT DONT WORK MADRIX HAS I CONVERT THE 5 PIN TO 3 ..AND I GUESS PIN 3 IS THE DATA AND THAT IS MY GREEN WIRE ON THE PIXEL ...ANY HELP PLEASE BEFORE I RETURN EVERYTHING ..OR ANY WEB WIHT WIRE DIAGRAMA
Re: MADRIX LUNA WIRING
Hello jaime,
It seems you want to connect SPI controlled LED Pixel Tape to the MADRIX LUNA.
But the LUNA is an Art-Net and sACN to DMX interface. That means you can connect every desired DMX fixture to the LUNA but no SPI chip based fixture.
Now you will have two possibilities:
1) Use a MADRIX NEBULA instead of the MADRIX LUNA to connect the desired SPI tape.
2) Connect an additional DMX to SPI converter between the output of the LUNA and the Pixel Tape.
jaime
Post by jaime »
yeah thank you i will remplace it for nebula
Hello deresta,
Can you please elaborate the occured issue a bit more in deep?
What kind of fixtures you want to control?
We are looking forward to hearing from you!
