Copy Fixtures across Z Layer
AnthonyLP
Post by AnthonyLP »
Hey all just seeing if its possible can i copy a fixture layout i have done on z layer 1 and copy it acorss to multiple z layers
Cheers
Ant
Re: Copy Fixtures across Z Layer
Hi AnthonyLP,
1) Select all your fixtures on Z-Layer 1.
2) While holding the CTRL key to copy the fixtures, move your mouse (and the copied fixtures) to an empty area below.
3) In the "Voxel Mapping Settings" (on the right side of the Patch Editor) set the Position Z to "2" for the copied fixtures.
4) In the last step bring back the copied fixtures to the correct start position on Z-Layer 2.
I hope this helps you.
Have a nice day!
