Scenes wont remove
Quinton
Scenes wont remove
Post by Quinton »
Hi Team,
I'm having a bit of a problem with old scenes not completely deleting. It seems the scene itself is deleting but reference to it remains which causes a problem when setting up cues because it references the old non-existent scene. I have updated firmware but still same issue. Can you please assist.
Re: Scenes wont remove
Hello Quinton,
If you have assigend a scene in a Cue of the AURA Cue List and you delete the scene, the Cue will not be deleded also. Because you can assign another scene to the created Cue.
That means if you want to delete the scene and also the assigend Cue of the Cue List, you have to delete it in both menus.
On the other way arround. If you delete a Cue of the Cue List the scene will not be deleted. You will still find it in the Scene menu and yiz will have the possibility to assign it in another Cue.
Quinton
Post by Quinton »
Thanks Guertler i have now deleted from both menus -this worked :)
