Layer delay time
HBonello
Layer delay time
Post by HBonello »
How can I add a delay to start each layer at different times when I select a storage place? 😅
Re: Layer delay time
Hello HBonello,
The layers of the activated Storage Places are always playing. But you will be able to fade in (change the opacity) of the desired layers after a "delay" time with the help of the Storage Place Chaser.
More about the Storage Pace Chaser you can learn under the following link:
http://help.madrix.com/m5/html/madrix/i ... haser.html
If you want to change the opacity of layers please change the "Parameters" to "Layer Visibility Settings". After changing the settings you can create the desired chaser.
HBonello
Post by HBonello »
Thank you @Guertler,
I know the chaser option and I tried it before posting, but for my effect it didn't work because i'd like to have the start of the effect delayed in relation the the others.
I also tried to have the chaser delaying the layer from speed 0 to X but it also didn't work.
Any way to accomplish this?
Hello HBonello,
Can you please explain a bit more what you want to achieve?
Maybe we will find a solution with the help of the MADRIX Macro in combination with the MADRIX chasers.
