How to store images permanently
donaldashley
Post by donaldashley »
Hello everyone, I hope this is not a repost but I’m tired of getting nowhere. So my question is “How can I store images permanently?”. Thanks very much!
Re: How to store images permanently
Hello donaldashley,
If you want to work work with images in MADRIX 5, simply choose the "SCE Iamge" effect at an desired Storage Place and load the desired images in the "Image Table".
Everytime when you activate this Storage Place the loaded images will be displayed at the created matrix.
Under the following link you will find more about the "SCE Image Effect":
http://help.madrix.com/m5/html/madrix/i ... itmap.html
After all settings are correct please save the MADRIX setup via "File > Save" or "File > Save As..." Now the images will be loaded also at the next starts of this MADRIX setup.
Please note: If you want to open the created setup at another PC you have to copy the images also to the desired PC at exactly the same directory. MADRIX will call the images and they will not be saved in the setup.
