Separate control
Weir Mountain
Separate control
Post by Weir Mountain »
Is it possible to have individual zones of control from one madrix installation? For example, I have a building we have one area we want to run scenes on and the other to be a static color. Is this a possible or a wishful thinking?
Re: Separate control
Hello Weir Mountain,
With the help of multiple effect layers and working with the Mapping in MADRIX 5 you will be able to assign each effect layer to a desired position. So you are able to control different zones of the full patch with different MADRIX effect layers. Under the following links you can learn more about working with effect layers and the mapping in MADRIX 5:
http://help.madrix.com/m5/html/madrix/i ... rray_.html
http://help.madrix.com/m5/html/madrix/i ... ialog.html
http://help.madrix.com/tutorials/m5/HTM ... ayers.html
http://help.madrix.com/tutorials/m5/HTM ... pping.html
http://help.madrix.com/tutorials/m5/HTM ... e_gro.html
