Looping TimeCode?
viatekh
Looping TimeCode?
Post by viatekh »
Hi all.
Does anyone know if the MADRIX MTC Generator can loop Timecode?
Failing that, is anyone aware of a 3rd party Timecode generator that can loop MTC messages?
We have an install that we want to run on a 1 hour loop.
Thanks.
Re: Looping TimeCode?
Hello viatekh,
Welcome to the MADRIX form.
The MADRIX 5 Time Code Sender can't run time codes in a loop.
But MADRIX is able to run a cue list in a loop without time code. Simply add the desired cues in the Cue List, set a Duration for every Cue and run the Cue List. If MADRIX will be at the end of the Cue List, it will start at the beginning of it again.
If the sum of the Duration of all Cues in the list is equal an hour, the loop time of the Cue List will also be an hour.
