Midi Mapped Audio Input very laggy
Ismal
Post by Ismal »
On Madrix 5.5.0.151 with Win10,
When mapping a midi slider to 'Audio Input Level', it is very laggy if the slider is moved to fast. If you move the slider very slowly it is ok.
Tested on several machines with different midi controllers, with WDM audio device as 'Stereo Mix', 'Line Input' and 'Mic Input'.
When using ASIO soundcard, issue is not present.
Re: Midi Mapped Audio Input very laggy
Hello Ismal,
Can you please share some more information because we can't reproduce the issue. We have test it with an "AKAI - APC 40 MK II".
Please send us the infromation which MIDI contoller you are using and also a MADRIX logfile when the MADRIX 5 KEY is connected to info[at]madrix[dot]com.
