Time code failure
CARLOSLUCES512
Time code failure
Post by CARLOSLUCES512 »
Hi I'm running with 5.5a Ver and the problem is one time I close the show the next time when I open the time code is losing I need to refresh the list so I must to go to SMPTE ( for example) and return to timecode for to have again the time code I using the internal clock and check the problem in a couple of pc and the result was the same..
Thank you for you replay.
Re: Time code failure
Hi CARLOSLUCES512,
I'm sorry but there is an issue with the time code in MADRIX 5.5a. We will fix this issue with the next upcoming MADRIX 5 release.
We are sorry for the inconvenience!
CARLOSLUCES512
Fantastic
This reported issue is now fixed in MADRIX 5.5b.
Under the following link you can download the latest MADRIX 5 version:
