Changing BPM using if>then statement
webcentrik
Post by webcentrik »
I'm trying to create an effect where a line moves across the matrix but varies its speed based on position. I have tried using the if>then statements examining the xpos of the line but I am getting something wrong in the syntax or use of the SetBPM command when nested in an if>then statement.
Can anyone look at this and point me in the right direction.
// Global Vars
float mw;
float mh;
int xdir;
int ydir;
float xpos;
float ypos;
// Global Colors
color col = {255,255,255,0}; //White
color col2 = {127,127,127,0}; //Gray
color col3 = {255,0,0,0}; //Red
void InitEffect()
SetBpm(600.0);
SetAsync(true);
xdir = 1;
xpos = 0.0;
mw = (float)GetMatrixWidth();
mh = (float)GetMatrixHeight();
void RenderEffect()
//Calc Position and Direction for X
if(xdir == 1)
xpos += 1.0;
if(xpos == mw-1.0)
// xdir = -1;
xpos=0;
if (xpos == 30)
(SetBPM(900.0);)
else
if (xpos == 60)
(SetBPM(1200.0);)
else
if (xpos == 90)
(SetBPM(600.0);)
//Draw Matrix Black
ClearAlpha(255);
//First Vertical Line
DrawVectorLine(col2,(xpos-1.0)/mw,0.0,(xpos-1.0)/mw,1.0);
DrawVectorLine(col,(xpos+4.0)/mw,0.0,(xpos+5.0)/mw,4.0);
DrawVectorLine(col3,(xpos+8.0)/mw,0.0,(xpos+5.0)/mw,4.0);
void MatrixSizeChanged()
InitEffect();
Re: Changing BPM using if>then statement
Hello webcentrik,
There are several issues in the posted MADRIX Script:
    • The function SetBPM isn't correct. If you want to change the BPM value, you will need to use the function SetBpm(float value)
    • In case of working with brackets at the If Statements you will need to use curly brackets instead of round brackets. Example:
      Code: Select all
      if(condition)
          statements
      In your posted code you are working with only one statement per if respectively else if condition so you don't need to add the curly brackets Example
      Code: Select all
      if(condition)
          statement
    • In the If condition you are comparing float values but some of the values are still integer.
