Newbie question
WayneGallagher
Newbie question
Post by WayneGallagher »
Hello there. I’m new to Madrix and I need some help here. I wonder if it is possible to control non-color channels of LEDs? Thank you for your time in reading and responding to my question. Hope to learn lots!
Re: Newbie question
Hello WayneGallagher,
MADRIX is designed to control the colors of the desired fixtures. Every brightness changes and so on are realized via the color channels of the fixtures. By default all other channels are set to a fix value.
If you want to control a non color channel dynamically in MADRIX, you will need to assign it to a color control. Otherwise it can't be controlled. That also means you will need to have in mind which color representation in MADRIX is respondsible for what function of the fixture.
In other words... Of course thechnical it is possible but it isn't recommended. Maybe you can explain a bit more what you want to control.
