Trigger Cues from Onyx
InvisiTech
Post by InvisiTech »
Can I trigger selected cues in Madrix 5 from Onyx Obsidian and vice versa?
Re: Trigger Cues from Onyx
Hello InvisiTech,
You can easily control MADRIX remotely via DMX, Art-Net or sACN. That mean if you connect the desired console with the MADRIX PC and send one of the named protocols, you will be able to trigger a cue of the cue list or change the activated storage place for instance.
More about the MADRIX remote functionality you can learn under the following link:
https://help.madrix.com/m5/html/madrix/ ... ation.html
Under the following links you can learn how to configure the DMX remote control in MADRIX 5:
https://help.madrix.com/tutorials/m5/HT ... mx_in.html
https://help.madrix.com/tutorials/m5/HT ... t_net.html
https://help.madrix.com/tutorials/m5/HT ... x_in_.html
If MADRIX should trigger the console, the console must provide the functionality to work with DMX input trigger. Might you know MADRIX is able to send the data via DMX, Art-Net or sACN.
If this will be the case, you will need to add a fixture which controls the console to the patch and create the desired content for that fixture per storage place.
But the common way is that MADRIX is the slave and the console will trigger it.
I hope this will help you.
InvisiTech
Thank You! Work's perfectly!
