Invert Z Axis From CSV Fixture List Import?
Alex_V
Post by Alex_V »
I am attempting to import XYZ positions for my fixture configuration from a CSV file via the "Import Fixture List" dialogue. The imported fixtures are upside down (Y) and backwards (Z) on import into the patch editor. I have been able to solve the Y axis by going to "Edit > Flip Selection Vertically" but can't seem to figure out how to invert the Z layers so that when the default view is set to "Front" the fixtures in my preview window are oriented correctly. Is there a quick way to invert the Z axis so the LEDs are oriented correctly in Madrix? Thanks.
Re: Invert Z Axis From CSV Fixture List Import?
Hi Alex_V,
Unfortunately there is no quick way to do it in the current MADRIX 5 version. I'm sorry.
With the next MADRIX 5 release you will be able to use negative values for "Scale X / Y / Z", which will invert the positioning of the fixtures along the appropriate axes. We can inform you via e-mail, once this feature becomes available.
