Timeline start with end cue
Dingken
Post by Dingken »
Before I start to play the timeline, I usually running a cue which is standby or blackout, which is directly click the deck or cue list.
When I star to play the timeline, it usually flash out around half second end cue from the timeline and then running smoothly.
Any suggestions to solve this problem?
Best Regards,
Ken
Re: Timeline start with end cue
Hello Ken,
We can't reproduce the occured issue.
Can you please send us the MADRIX setup and a MADRIX logfile after the desired setup was loaded via e-mail to info[at]madrix[dot]com?
Please navigate in MADRIX to "Tools > Logfile", click the button "Save As..." and enter a name for the Logfile.
federicorottigni
Post by federicorottigni »
Hey guys, we are actually experiencing the same exact problem. Crashing our head on it since days but not able to come up with a solution.
We are sending as well to the attached email "info-madrix" Logs and Setup (as requested to the previous user).
Thank you for the help in advance.
Federico
Hi Federico,
We are still not able to reproduce the issue.
Please send us the MADRIX setup and a MADRIX logfile after the desired setup was loaded to info[at]madrix[dot]com.
Thanks in advance!
