Upgrading to Madrix 2.11
mission_rave
Post by mission_rave »
May be this is silly question. But if install madrix 2.11 over the old version which is running , will it clear all my art-net & devices settings?
mission_rave
Re: Upgrading to Madrix 2.11
anyone? i need to upgrade soon..!!
Nearly all of the settings of your show are saved in your so-called MADRIX Setup File (*.ms2).
Upgrading (for example from 2.10 to 2.11) is no problem. But just to be sure, you should make a backup of your MADRIX Setup files. If you have made any changes to the MADRIX Fixture Library (madrix.mfl) via the Fixture Editor, you should also backup this file, as it will be overwritten.
But downgrading (for example from 2.12 to 2.11) is NOT recommended.
mission_rave
sorry i made a mistake while typing. i meant upgrading to 2.12
