demo software dmx limitations
ManMartin
Post by ManMartin »
hello
I have seen that now your demo software sends dmx, I tried with open dmx from enttec to check the configuration of some eurolite tubes.
I want to know the limit of channels and the turn off sequence of the dmx signal and also if the artnet output is also enabled to use it for configuration and setup purposes in the installations before the software is received with the dongle in its dvd package.
cheers from malle.
Re: demo software dmx limitations
Hi ManMartin,
The demo version contains the fully functional software. But as you know the data output is restricted.
In demo mode, MADRIX sends data for one hour. But the output is switched off and on again every minute or so during that period (This is totally random and not a fixed interval).
You can use a lot of DMX channels (256 DMX universes) and Art-Net is also enabled, yes.
So, yes, you can create and test the configuration and setup without the dongle.
Regards
