custum snake fx
hanzie87
custum snake fx
Post by hanzie87 »
Is it possible to create a custom snake where you can draw the path of the snake(s)?
In example when you have deco cube elements but you only want a circular motion on the outline...
or are there better effects to achieve this?
Re: custum snake fx
Hi hanzie87,
Welcome to the MADRIX Forum!
- Sorry, but this is not possible.
- There are several ways to achieve this behavior using different effects.
- I recommend to try out the "SCE Wave / Radial" effect with the shape set to "Radar". This allows you to create the wanted motion.
I hope this helps you.
