How to synchronize lighting effects across multiple LED luminaires
JayAlbert
Post by JayAlbert »
I'm thrilled to be a part of this vibrant group of lighting enthusiasts. I have a question regarding the Madrix software: How can I synchronize the lighting effects across multiple LED fixtures to create a cohesive visual display? Any tips or tutorials that you could point me towards would be greatly appreciated.
Re: How to synchronize lighting effects across multiple LED luminaires
Hi JayAlbert,
Welcome to the MADRIX Forum!
You can achieve this by using an Art-Net interface, which supports ArtSync for the data output. All our interfaces support the ArtSync feature. You can enable ArtSync in the Device Manager of MADRIX 5. Therefore connect your interface and navigate to "Preferences" > "Device Manager" > "Art-Net" and enable the ArtSync checkbox.
Here you will find further information (part - Sync Mode):
https://help.madrix.com/m5/html/madrix/hidd_device_page_net.html?zoom_highlightsub=artsync
https://help.madrix.com/tutorials/m5/HTML/hidd_connecting_madrix_5_with_art-n.html
The content (effect) needs to be mapped on the complete matrix or a desired range of fixtures.
Learn more about the "Map" feature in MADRIX 5:
https://help.madrix.com/m5/html/madrix/hidd_map_dialog.html?zoom_highlightsub=mapping
https://help.madrix.com/tutorials/m5/HTML/hidd_layer_mapping.html
https://help.madrix.com/tutorials/m5/HTML/hidd_create_fixture_groups.html
https://help.madrix.com/tutorials/m5/HTML/hidd_layer_mapping_with_fixture_gro.html
Counconect
Post by Counconect »
Thanks for the source
Ali01Fakhroo
Madrix Mapping
Post by Ali01Fakhroo »
Hello, I'm kinda new to Madrix I recently got the software I have a question about the mapping on the patch editor so Im working on 6 flexible RGBW lights each light is 1.2m and each member has 4 pixels for some reason when I keep them in Madrix the mapping is not correct it's not in the right order say in the feature I get a big project and have to use 1000m, for example, I have to map every single pixel?
Thank you,
