Madrix and MA2
Galo77
Madrix and MA2
Post by Galo77 »
Hi everyone,
I'm new to Madrix.
For some reason I'm unable to edit or add new effects on madrix while is connected to MA2 as remote.
Is this normal, is there a way to make changes, am I missing a setting?
Thanks in advance
Re: Madrix and MA2
Hello Galo77,
I assume the "Execution" is set to "Always" in the DMX-IN Remote Editor. Please navigate to "Preferences" > "Device Manager..." > "DMX Input", select your input device and your remote configuration and click "Edit". The DMX-IN Remote Editor will be opened. Now you can change the "Execution" column to "On Value Change".
If Always is selected, the remote command will be permanently and continuously processed by the software. If On Value Change is selected, the remote command will only be processed when the incoming value on this DMX channel has changed.
Here you will find further information:
https://help.madrix.com/m5/html/madrix/index.html?hidd_dmx-in_remote_editor.html
Galo77
Re: Madrix and MA2
Post by Galo77 »
Thanks for your reply Schulze
