Groups update
Nicolas delight
Groups update
Post by Nicolas delight »
Hi everyone,
I’m working on a project which I’m preprogramming timelines for.
I’m using a lot of different groups that have been arrange in different voxels with different z layer.
When I’ll be on site If I need to rearrange the fixtures in the different voxel according to the real world it will affect/change my groups.
Will it affect my differents timelines ?
Is there a way to update my groups so it doesn’t change my programmation ?
Thanks.
Best regards.
Re: Groups update
Hello Nicolas delight,
The Fixture Groups will be updated as soon as you change the posisition of fixtures in this group. That means the next time when you will use the desired Group for Mapping it will use the new size.
But once you have used the group for mapping and you are chancing the positions later on, the Map Size won't be updated.
In that case you have to assign the group again in the Mapping of the effect layers.
Nicolas delight
Re: Groups update
ok, thank you.
