How to make spacing in between LED strips
AzidTech
Post by AzidTech »
Hi guys.
I'm also a newbie here to madrix and just need help with a "simple" problem.
I am making an LED tunnel 10m long by 4m wide, the strips are running the length of the tunnel (600pixels) long, and I am going to put 12 strips in there which I am going to space out over 4m.
My question is, how do I set up the matrix to account for the space between the strips, which would be ruffly 35cm apart so my effects are not crushed.
Re: How to make spacing in between LED strips
Hello AzidTech,
The MADRIX dimensions in the Patch Edior are specified in pixel. That menas you would need to messure the size of one pixel and bring it in relation to the 35cm.
For instance if a pixel as a dimensionsion of 1 cm and the space between 2 LED stripes will be 35 cm, you will have a space of 35 pixels.
