Hue Bulb support
reporter
Hue Bulb support
Post by reporter »
I have a client that has put a bunch of new Hue bulbs in their club. These are LCA007 bulbs. The look similar to the LCT010 bulbs, but I can't control them in Madrix, although they do show up in the Hue app and when using the Hue API. Here' are the details of one of the lights.
I don't know whether the light is just unsupported, or if there's some other issue.
Code: Select all
	"state": {
		"on": true,
		"bri": 151,
		"hue": 3494,
		"sat": 223,
		"effect": "none",
		"xy": [
			0.591,
			0.3636
		"ct": 153,
		"alert": "select",
		"colormode": "xy",
		"mode": "homeautomation",
		"reachable": true
	"swupdate": {
		"state": "noupdates",
		"lastinstall": "2025-03-18T18:59:28"
	"type": "Extended color light",
	"name": "Hue color lamp 1",
	"modelid": "LCA007",
	"manufacturername": "Signify Netherlands B.V.",
	"productname": "Hue color lamp",
	"capabilities": {
		"certified": true,
		"control": {
			"mindimlevel": 200,
			"maxlumen": 1100,
			"colorgamuttype": "C",
			"colorgamut": [
					0.6915,
					0.3083
					0.17,
					0.7
					0.1532,
					0.0475
			"ct": {
				"min": 153,
				"max": 500
		"streaming": {
			"renderer": true,
			"proxy": true
	"config": {
		"archetype": "classicbulb",
		"function": "decorative",
		"direction": "omnidirectional",
		"startup": {
			"mode": "lastonstate",
			"configured": true
	"uniqueid": "00:17:88:01:0c:e1:23:75-0b",
	"swversion": "1.122.2",
	"swconfigid": "D11C1AA7",
	"productid": "Philips-LCA007-1-A19HECLv1"
Thanks,
Nathan
Re: Hue Bulb support
Hi Nathan,
I'm sorry, but the LCA007 fixtures are not supported.
Here you will find a list with all supported Philips Hue fixtures:
https://help.madrix.com/m5/html/madrix/hidd_philips_hue.html
FranciscoGarfield
Post by FranciscoGarfield »
Interesting problem with those LCA007 Hue bulbs! It's like hitting a wall in Snow Rider 3D when you think you're clear. Madrix not recognizing them despite Hue app functionality suggests a compatibility issue. Perhaps the API calls are slightly different for these newer bulbs? Unsupported hardware is a possibility. Hopefully, someone has experience integrating these specific bulbs, otherwise, a direct support query to Madrix might be the best path forward.
