Help!! No Output??
Help!! No Output??
I have a legit key of Madrix, I am trying to setup my Chinese Eurolite T9 (huasantech) -- I dont have any DVI output at all in Madrix. I set everything up and defined the matrix, but nothing appears.
Whats going on?
Whats going on?
Re: Help!! No Output??
mostly this happens if you have used DMX fixtures instead DVI fixtures for your patch. Check this out.
Yes, that was part of the problem. I was in such a hurry to get it up and working I overlooked that. Also, instructions said to setup running LEDshow first, then minimize and then run Madrix on top. Once that happened all i saw was blinking and flickering.
After spending an hour with the tech online, I realized that Madrix could be setup by itself using Eurolite T9 settings, proper matrix size, and also setting to DVI setting. Originally i had it configured that way, but had to change the matrix size, and forgot to reset from DMX to DVI.
Thanks for the help though.
