Questions regarding Patch / Existing installation
r2.lighting
Post by r2.lighting »
Hi Folks,
A friend of mine has acquired a location with a MADRIX 3 installation. It features LEDs arranged in a circular fashion. I've attached a few images and videos of the system in action.
When I open the patch, the fixtures are not arranged in any form or shape resembling their real world physical arrangements. At least not to my eye.
Can you shine some light on this? Is this probably a limitation of version 3? Does this make any sense to you guys as more experienced MADRIX users?
Screenshot 2025-04-13 164838.png (303.06 KiB) Viewed 1412 times
Re: Questions regarding Patch / Existing installation
Hi r2.lighting,
The MADRIX patch often differs from the physical arrangement, depending on the effects you want to achieve. For example a circular shape can be also patched using straight lines. I assume this has been done in the sent images. It is not always required to build the patch according as it is in the reality or according to the physical arrangement.
