Question regarding data cabling
r2.lighting
Post by r2.lighting »
Folks, I've got the following setup:
We are using MADRIX NEBULA controllers. I understand that ideally we'd do a snake data cabling, so start with the top strip to the right. Cable from the left end of the top stripe to the left end of the second from top. Then cable from the right end of the second from top to the right end of the third from top and so on.
However, is there any way to inject data into each stripe on the same side (e.g. the right end of each row)?
Re: Question regarding data cabling
Hi r2.lighting,
Only if you use a separate MADRIX NEBULA port for each LED strip / line. The LED tapes do have a fixed direction for the data signal, normally indicated with a small arrow.
