3D Volumetric Patch
Bezel
3D Volumetric Patch
Post by Bezel »
I'm trying to create a "chandelier" of hanging pixel tape products that is 8 x 32 and each piece of tape is 170 pixels long. When I create the 3D patch it seems that I cannot have Madrix prioritize the addressing in the vertical Z axis before moving on to the next fixture when I specify a count of X=32 Y=8 Z=170.
Thanks.
Re: 3D Volumetric Patch
Hi Bezel,
Welcome to the MADRIX forum!
You want to patch the addresses in z-direction, right?
If yes, this is not possible with the "Add Fixtures" or "Matrix Generator" dialog. But you can create a corresponding 1x1x170 fixture with the Fixture Editor, where the address are layed out in z-direction. You can find the Fixture Editor in the installation directory of MADRIX 5 (default: C:\Program Files\MADRIX5).
Here you can learn how to create fixtures with the Fixture Editor:
https://help.madrix.com/tutorials/m5/HTML/hidd_creating_fixtures_with_the_fix.html
