HD108 Addressing Issue
MrGravy
Post by MrGravy »
Hello! I need some advice on addressing this strip properly.
I am running an HD108 strip through a LeDMX Max. The strip has 80 pixels. Got it hooked up but only the first 40 pixels were displaying.
I remembered HD108s having a gray channel, so thinking they require 6 channels per pixel, I added a 3 channel offset to see if I could just skip those. It sorta worked. All the pixels displayed, but I lost the blue channel? So now I am a bit confused. Any pointers?
Let me know if you need more information!
Thanks.
Re: HD108 Addressing Issue
Hi MrGravy,
Welcome to the MADRIX Forum!
I'm not sure how the 3rd party interface handles HD108. With the MADRIX NEBULA we implemented a 8 Bit and 16 Bit variant of the protocol. The 8 Bit one is using 3 channels and the 16 Bit one 6 channels per pixel and there is no need to set an offset. In MADRIX 5 you can simply use the "!generic RGB Light 1 pixel" fixtures.
You can test each channel the following way:
1) Connect your interface and the LEDs.
2) Launch MADRIX 5, discover the interface. Enable all ports.
3) Navigate to "Tools" > "DMX Fader Tool". You now have the possibilty to send data on the set universe and channel.
This would allow you to figure out what each of the channels does. The Fader Tool overwrites the "normal" output, make sure to deactivate it after testing the channels. I recommend to also contact the manufacturer of the interface.
MrGravy
Post by MrGravy »
Thanks for the reply!
The LeDMX Max is selected as HD108-4MHz and RGB 16 bit.
The channel fader showed
Channel 1 pixel 1 red
Channel 2 nothing
Channel 3 pixel 1 green
Channel 4 nothing
Channel 5 pixel 1 blue
Channel 6 nothing
Channel 7 goes to the next pixel...
When I create a matrix with generic RGB it assigns 3 channels per pixel. What am I missing?
MrGravy
Post by MrGravy »
Talked to the module manufacturer and they confirmed odd channels coarse, even channels fine...
So every pixel needs 6 channels.
Selecting generic RGB only gives 3 channels per pixel.
Is there a different fixture I can select, or a way to tell Madrix i need 6 channels?
Hi MrGravy,
You could create a custom fixture with the Fixture Editor, where the second channel is defined as red, the fourth as green and the 6th as blue.
I can send you the required fixture. Please send a short message to info[at]madrix[dot]com.
Thanks in advance!
