Syncronizing Multiple Madrix Computers
Someplace I read how to synchronize multiple computers running Madrix. But now I can't find it. I don't remember if it was in a post in this forum, the help file or someplace else. Maybe somebody can point me to where this is documented (unless I am imagining it)?
Thanks in advanced!
Mark
Thanks in advanced!
Mark
Re: Syncronizing Multiple Madrix Computers
OK - I found it under "Backup System" in the help. The heading is a little misleading because although it's main purpose is as a backup in case one computer fails, it also functions to synchronize multiple computers over ethernet. The help file says...
"Receive Sync Command From Master" is a useful feature to play cue lists synchronously.
I assume somebody is using this successfully although I've never seen a forum post about it.
Mark
Mark
Sorry MarkC, i saw your post to late.
And yes you found it!
The Backup System solution wasn´t made originaly for this aim, but can be used for this.
