acclaim x-net 8
acclaim x-net 8
Hi any experience with acclaim x-net 8?
Does this support DMX in through all 8 ports?
Urgent!
Urgent!
Re: acclaim x-net 8
No it don't says Acclaim, only artnet in and dmx out.
Re: acclaim x-net 8
Yes, Art-Net in and 8x DMX out.
But in the past we made the following experience with it.
If you are using only a view ports 4x DMX out for example and just enable this 4 ports inside MADRIX you get delayed signals on the different ports.
Of any reason it is nessesary to enable all 8 ports in MADRIX also if you do not use all to get a stable and fast signal on the used ports.
