static layer maps
static layer maps
How do I store my matrix map elements for easier use in layers
I have a number of display elements (matrix, megatree, lightpoles) that I have mapped my elements of various sizes onto 150 x 100 matrix, how do I store the elements as seperate areas on the master map so that I can easily select the element on that layer without having to hand select the individual areas every time.
So rather than selecting the area for the layer I would like to click on the area where say my matrix lives and control click on other areas to add other areas if I need to have that layer across multiple areas.
Re: static layer maps
Sorry, currently this is not possible with MADRIX.
We suggest to create one storage place as template where you map 3 layers for example.
Than using this storage place with copy and paste into a new storage place and select the effects you have in mind.
thanks Wissmann for the workaround that I will use for this year.
I have added this to the features requests
Thanks for that!
Just a tip:
You can speed up the copy process. Just go to the menu Edit -> Copy Storage Places. You will have some quite convenient options there.
Just a tip:
