need scripting help
dieter
need scripting help
Post by dieter »
I will build a effect script with an min and max slider for build a range. What I must do? Value for min are never higher then max value and max value never lower then min value automatic.
How program that?
Here my not perfect script test.
Code: Select all
@scriptname="SliderMinMaxRange";
@author="Dieter";
@version="1.0";
@description="11/14/2011";
int	maxX=GetMatrixWidth();
int maxY=GetMatrixHeight();
ctrlslider sliderMin={"Min",1,maxX*1/4,maxX};
ctrlslider sliderMax={"Max",1,maxX*3/4,maxX};
void InitEffect(){
	// get size
void RenderEffect(){
	Clear(); // clear screen
    // get value of slider
	int maxValue=sliderMax.value;
	int minValue=sliderMin.value;
    // check range
	if(maxValue<minValue)maxValue=minValue;
	if(minValue>maxValue)minValue=maxValue;
    // set value of slider
	sliderMax.value=maxValue;
	sliderMin.value=minValue;
    // draw rectangle
	FillPixelRect(WHITE,0,minValue-1,maxX,maxValue-minValue+1);
	DrawPixelRect(RED,  0,minValue-1,maxX,maxValue-minValue+1);
void MatrixSizeChanged(){
	InitEffect();
Can anyone help me?
Re: need scripting help
try this
Code: Select all
@author="Dieter";
@version="1.0";
int maxX,maxY;
ctrlslider sliderMin={"Min",1,100,100,"Min"};
ctrlslider sliderMax={"Max",1,100,100,"Max"};
void InitEffect()
	// get size
	//Init Slider ranges
	int sMin = (int)((float)maxY*0.25);
	sliderMin.rangeMax = sMin;
	sliderMin.value = sMin;
	int sMax = (int)((float)maxY*0.75);
	sliderMax.rangeMax = sMax;
	sliderMax.value = sMax;
void RenderEffect()
	//check range
	if(sliderMax.value < sliderMin.value) sliderMax.value = sliderMin.value;
	if(sliderMin.value > sliderMax.value) sliderMin.value = sliderMax.value;
	// draw rectangle
	FillPixelRect(WHITE,0,sliderMin.value-1,maxX,sliderMax.value-sliderMin.value+1);
	DrawPixelRect(RED,  0,sliderMin.value-1,maxX,sliderMax.value-sliderMin.value+1);
   InitEffect();
dieter
Post by dieter »
Hi wissmann,
sorry but you don't understand my problem.
I don't will limit the range of slider or output.
I want:
If I slide the max slider lower the min slider then also move the min slider lower.
If I slider the min slider higher the max slider then also move the max slider higher.
If you test my script you see one direction running fine but the inverse way running not really good.
Pinzer
Post by Pinzer »
Hi dieter,
maybe this is what you are looking for.
Code: Select all
@author="Dieter";
@version="1.0";
void InitEffect(){
   // get size
   int newmaxValue=maxValue;
   int newminValue=minValue;
    // check range
   if(minValue>maxValue)newmaxValue=minValue;
   if(maxValue<minValue)newminValue=maxValue;
   sliderMax.value=newmaxValue;
   sliderMin.value=newminValue;
    // draw rectangle
   FillPixelRect(WHITE,0,minValue-1,maxX,newmaxValue-newminValue+1);
   DrawPixelRect(RED,  0,minValue-1,maxX,newmaxValue-newminValue+1);
   InitEffect();
