storage place bitmap bubbles not always show
dieter
Post by dieter »
I have a little bugging problem with storage bitmaps for preview the storage places.
do follow steps:
Select a effect an storage A1.
press left mouse button over A1 and shift via drang and drop to A60.
If your mouse pointer over A60 then popup the bitmap for the effect.
If you go with mouse pointer over the place A1 then no bitmap popup.
If you away from A1 and repeat go A1 then popup bitmap show.
It is not fine.
If I sort my setup it is peeving.
Re: storage place bitmap bubbles not always show
Hi Dieter,
thx for this report.
We have fixed this for the next release.
edeferaxy
Post by edeferaxy »
How do you change a BITMAP picture to a JPEG picture? Whenever I want to save a picture, it only comes out as bitmap picture file. It does not say anything else except bitmap. How do I fix it?
_____________________________________
affiliateelite ~ affiliateelite.com ~ adgooroo ~ adgooroo.com
I Gues you speak about the export option in the SCE Bitmap image table. There only the BMP file format is offered by us. So converting the bmp into a jpg you have to do outside of MADRIX.
