Some S2L effects not working (EQ presets)
Hi-
I have been using Madrix with a Showvision LED curtain, and have not been able to get some of the S2L effects to work. Namely, the EQ style effects. The level meter DOES work as it should (which tells me I have the audio set properly), as well as the "wave graph", but the EQ presets just yield a black screen.
Should these all work the same, or is there some other setting for the EQ effects to function properly? thanks in advance.
MR
MR
Re: Some S2L effects not working (EQ presets)
Sounds strange.
Please can you send us your setup and logfile?
