rename layer problem
rodericwilson
Post by rodericwilson »
if you right click on a layer ,select rename , rename the layer then - to save clicking and time right click on the next layer to rename that - then the first layer shows the new name but does not seem save it when you go back to that storage place - as i found to my great displeasure after i had renamed about 100 layers that way . :(
Re: rename layer problem
thank you very much for this bug report and sorry for that.
We will fix this issue with the next release.
Fixed in MADRIX 2.14.
