Colossus High Definition video recorder
hello. I have a problem plugging the Colossus video recorder card. madrix can not pick up the signal says to close all programs that work with the card. real-time map itself with WinTV software works.
or will any views that run madrix houppage Colossus card?
Re: Colossus High Definition video recorder
Did the SCE Video effect of MADRIX offers this card inside the capture dialog?
yes. i select colossus capture card, and madrix print:Wissmann wrote:Did the SCE Video effect of MADRIX offers this card inside the capture dialog?
"Close all aplications that work with colossus capture card."
all other aplications is closed, all other services is stoped.
It would be helpful if you could send us a log file to info[at]madrix.com.
thanks
thanks
This configuration is not exactly what I was looking for with Madrix because with an effect such as SCE drops I am getting the look of giant falling squares. All the LEDS on my 1x1 m panels are lighting at once. Is there a way to just light one LED on my 16 LED panel...is it possible for me to create a look (such as rain or snow) where only 1 LED is lighting.
______________________________________________________
http://www.learnalanguage.com/learn-english/
http://www.learnalanguage.com/learn-turkish/
http://www.gov.pe.ca/edu/elsb/
Just adjust the size of the drops inside the SCE Drops effect.
