H801RA Controller
tictac
H801RA Controller
Post by tictac »
I have a H801RA controller. Does Madrix support this controller?
Thanks for help
Re: H801RA Controller
Hi tictac,
MADRIX does not support this controller directly. But I have seen several notes saying that this controller comes with the software LEDStudio. Is that correct?
If yes, you can use "screen-capturing". MADRIX can generate a DVI output window (with MADRIX KEY dvi, for example) and LEDStudio can "capture" this output window and send the data to your LEDs.
I would recommend to test it with the MADRIX demo version!
