Frame per second
rko
Frame per second
Post by rko »
Hello
We juste purchased Madrix to work with a 2x 9mx5m wall of leds
I need to have the most fluid animations. I use a lot of video files, and I would like to know the limitation of LED panel / madrix corelation.
What's the reresh rate of Led? Do you know if I can go up to 50 frames per second?
thanks
Re: Frame per second
Welcome to this Forum!
This question is quite technical and certainly depends on the LEDs and the control system.
Can you please contact us at info[at]madrix.com and send all the documents and specifications about your LED wall?
This will help us answer this question for you.
Thank you very much!
rko
Post by rko »
I should maybe contact first the company who sold the walls.
then I will be back to you, cause I don't have any documentation about it.
I'll let you know asap.
thanks for your reply.
