When using two IP addresses Madrix cannot find CK PDS
saugust
Post by saugust »
We have a setup where we are using two static IP addresses on the same network card. We need the first one to be on a 24.X.X.X address to allow for remote administration of the computer through the internet. The second IP is set for 10.0.0.1 with a subnet mask of 255.0.0.0 and we can connect to the PDS power supplies using Quickplay Pro from CK but we cannot connect through Madrix. We have ensured that KiNet is enabled in Madrix and it shows the 10.0.0.1 interface is being used but no power supplies can be discovered.
Re: When using two IP addresses Madrix cannot find CK PDS
Hi and sorry for the late reply.
Did you check if MADRIX discover the PDS if your Network Card is running only on one ip?
One hint.
If you start MADRIX the first time the Windows System ask you if you allow the Access by Network. Within this Dialog you have two Options. Public Network and private Network.
Please enable booth Options.
